Imported Posts (Unmapped)
Hi all,
After reading quite a few threads about the Avant 55 over the years, I thought I’d share a few observations for anyone considering buying one used.
The Avant 55 is, in my opinion, one of the last “proper” B&O televisions — motorised stand, speaker movement, classic interface. But it does have some recurring weak points.
The most discussed issue seems to be the Digital Video Engine (video board). Typical symptoms are purple screens, horizontal lines, distorted image, or the TV powering on without showing a proper picture. Many MK1 units eventually needed a replacement board. Some owners report that replacement boards also failed again later, possibly due to heat.
Panel issues are another area to check carefully. Look for uneven brightness, green or purple lines, spots in the middle of the screen, or color shifts. Some of these issues are DVE-related, others appear to be genuine panel/backlight problems.
The motorised mechanisms are fantastic when working, but also worth testing thoroughly. Speaker movement and stand rotation should be tested multiple times to make sure nothing sticks or hesitates.
There are also occasional startup and HDMI quirks, but those seem less critical compared to the DVE and panel risks.
In short, the Avant 55 can still be a great buy if:
The video engine has been replaced (ideally documented)
The panel is clean and uniform
The price reflects the potential repair risk
When it works, it’s magical. When it fails, it can become expensive.
Would be interesting to hear long-term MK2/NG experiences as well.
