Avant : When the speaker is almost up, it slides down again...
Hi I have a Beovision Avant 55 from 2015 (1st gen) and I find that the speaker has started to slide down (when it is switched off). That is that when I switch off the TV, the speaker starts to go up in the TV, but when the TV is switched off and the speaker is almost up, it slides down again. What caused it?
Hi there, I have a similar problem with my Avant 55 (2016, wall bracket), slightly different. The speaker slides down when I switch the tv on, but before it is almost down, it slides up again. I read that changing the batteries might do the trick, but that didn't solve the problem. Anyone a clue what is causing this problem?
