Beomaster 4400 FM stereo indicator is permanently lit
On my beomaster 4400 the fm stereo indicator LED lights up when the beomaster is turned on no matter whether it is turned on with Phono, tape one, tape two or any of the FM buttons. I have tried to turn 3C8 as describen in the sevice manual but nothing happens.
Hallo hallo er her nogen? Anybody here? Jeg kan høre ekkoet :(
Unless a wire is shorting to something, which would be very obvious, it can almost only be a case of a bad stereo decoder IC. Martin
Thank you Martin :))  I have been looking for a short or wrong connection as I have changed both the radicator and the LED and also the on/off switch. I will look again and perhaps change the stereo decoder card with a spare one that I have. Thank you again for answering. Erling Steen
Solved; a classic:  Tiny little piece of solder between two legs of the stereo decoder IC Thank you Matin Regards Erling
Good job! Martin
These failures are difficult to find, one are always looking for component failures and at last it turns out to be something simple you dont think about, (except for Martin who have seen it all) good job, jeg er ekkoet
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
Martin suggested a short or the IC so I took a look at the IC and found a short :) Its a reminder; "always look for small pieces of solder"
