Hi all, I am currently on vacation, trying to repair my Beosystem 2500 cassette drive, which has a melted belt. No problem on that as I have a new spare with me. Problem 1 is if the right hand side pressure roller should flap around. There are two springs on the lift side roller, but only 1 on the right side roller. Is that correct? And will it be spring loaded once running in a specific direction? Question two, pleas esee pics. I have a loose tape head spring. I know how is should turn and what is up and down. But I cannot fixate it. Should the two small arrowed indentations fit under the two placj plastic tabs? and the very small bent tap on the spring, slide into a spring opening on the drive? See pics. Kind regards, Redfox.
