Beocenter 9500 No Output / Weak Right Channel
Greetings All! I just picked up a beautiful Beocenter 9500, my first B and O product.  I brought it home to do initial testing of the unit, only to find that the Main Passive Speakers have NO output, the Secondary speakers have Left channel and a VERY faint Right channel.  Headphone output is the same.  Left Channel is good.  VERY faint Right channel.  (Basically sounds like an unamplified signal) Before I tear into this thing, I want to reach out to the experts.  I am thinking the muting relay is probably to blame for the dead main speakers, and possibly the STK IC for the Right channel issue.  If you experts have any other ideas I would appreciate it. Thanks!  Oh, and the Powerlink sockets work with amplified speakers.  No issue there.
Hi and welcome to Beoworld!  The BC9500 is a great first purchase. First thing to check is simple:  Are you sure that there isn't a 3.5mm to 1/4 inch adaptor in the headphone socket?  Sounds silly but this mistake has been made many times in the past! EDIT:  But if the headphone output has the same problem this is unlikely - apologies!
Thanks!  It really is beautiful.  I saw it at the estate sale with a matching Beogram 9500 and had to have it. (Even though it was completely unneeded.  LOL) No adapter installed.  I used a 1/4 inch plug to test my headphones.  But I appreciate simple troubleshooting before tearing into a unit.
The muting relay is a likely suspect (trigger it on/off several times to see if there is any improvement). Check if the "dummy plug" is installed in the LINE IN/OUT on the rear connections panel (if removed, the pre-amp signal won't be going to the main amp, although this wouldn't explain the partly working secondary speaker output...). Also check the BALANCE adjustment.
"Bang & Olufsen - A Life Less Ordinary" // "It's not magic, it's the Bang & Olufsen link system" // "It takes more upon itself, asks less of you. And a natural consequence of this is the simple and striking design. The true harmony of form and function spells beauty in any language"
I triggered the "Mute" a few times, I didn't hear any clicks of a relay activating.  As far as the Line In/Out plug, it is installed. The Balance seems to operate correctly. Thanks for the response.
Update: New relay at R1 installed and no change.  Main L+R passive, no audio.  Secondary R is good.  L is weak. Any ideas from experienced B and O techs?
Update: Replaced TR22 and now the mains have audio.  Main and Secondary Right Channel is GOOD.   Main and Secondary Left channel is WEAK. I am leaning towards an STK module.  Do these regularly go bad? Thanks!
