Beomaster 4000 (2408) wiring diagram
Hello, I'm in the last stages of reassembling this unit after installing the restoration kit, but a few wires were detached in the process. I took photos as I went along, but apparently none of the particular sections I need.           Obviously I've had no luck finding a diagram, and I'm not savvy enough to figure it out without one. Thanks for any assistance / Jack
The service manual should be on site - You probably need to be a gold member to access these but there should also be a user manual there as well and a huge number of other manuals . It does depend on your ability to read circuit diagrams - something I certainly would have issues with but I suspect if you have done the restoration, you are more competent than me!!
Actually I recognise it ! I scanned it for the old Beoworld site so apologies for any quality issues if you get it - the circuit diagrams are clear though.
Thank you for the response. I have a user's manual, but I'm not able to determine wire routing from it. Jack
