B&O A9 Box
Hello all,
I am wondering if anyone had the original B&O A9 box they are happy to part with.
Regards,
Grant
I know B&O sell these.
Jacques
Thank you.
I have sent their customer service an email.
Cardboard box has perished in crawl space storage, but styrofoam from an A9 mk 1 is available if helpful.
Joe M in WV
I reached out to B&O locally and in Denmark, but was sadly told by both that they can't provide boxes.
Have you had a different experience?
Thank you Joe!
Grateful for your message.
If not too much trouble, would you be able to send me a photo to either my email or mobile number:
granthosie@outlook.com
+61414840756
Thank you!
Login to view image Login to view image10 years in the crawl space but substantially intact. Our crawl space is being encapsulated next week which is only reason these were noticed. Never flooded but the ones appear to be some black specks. Trash or treasure?
Joe M in WV
Spraying vinegar, or bleach (Clorox Clean-Up™ is bleach&soap&water), can sit on styrofoam without ruining it, I believe... Alas, I think he's in Australia which makes shipping this oversize monster from the USA kind of a waste?
May I ask which of the sheet products you are using to encapsulate? Folks always suggest Visqueen liners, like they used to put under mobile homes, but that doesn't work on crushed stone. I once found a multi-layer specialty product, but it isn't in Google anymore, just dozens of application contractors (thank you SEO companies).
Walls, posts and floors to receive 20-mil poly-reinforced crawl space liner with drainage channel mat below floor liner. Rim joists to be insulated with rigid board. Crawl space vents to be filled with insulation prior to wall liner application.
We had no idea that insulation had a service life. House is 40 years old. We are using a contractor. Dealing with 2000 sq ft removal of old powdery fiberglass myself? No thank you!
